I bought a Beat Bike Toba Crossbar in the need as at £1600 it was the only one I could afford from a shop. Although advertised with an Impulse 2.2 motor it arrived with an Impulse 2.0 motor. Not particularly exciting. Before the first charge (charging now, taken 4 hours so far) did 67 miles which was very good. Delay in engaging sixth gear which is a downer. Starting on hills is not easy and the walking mode I can't get to work continuously. I would not have bought it if my arthritis in my knees have no got so bad it was necessary (I might as well get it now than in summer). Changed the saddle for a cheaper one. Accessories fitted NOT readily available through 50 Cycles. Insurance through Cycleguard (bronze secure locks accepted). It feels sluggish compared to my previous Cyclamatic, but gets up the hills OK.
#624Perseus, Apr 13, 2017
PS: I can't say I'm happy with the Beat Bike Toba Crossbar. The delay in engaging sixth gear did not happen with the test bike. Beware! This gear change is frequent and occurs on every trip.
#625Perseus, Apr 15, 2017
Your bike uses the same Nexus Hub as mine (well, pretty much). I'm getting trouble around sixth gear as well (mine slips intermittently). Other gears are pretty much fine. Looking on various bike forums, there are quite a lot of mentions of them wearing out on a particular gear, so your problems may relate to that?
I'm no expert though.
Sent from my BBA100-2 using Tapatalk
#626Will Tinker, Apr 16, 2017
Worked all the time today (brief trip). Took the bike out just to try it out. I did get informed that the 8 gear hubs are much better than 7 gear hubs. Not wear as it is brand new.
Not a fault, just a naff product?
#627Perseus, Apr 16, 2017
100 miles. First clanking sounds. Dismissed as not important at the moment as only heard once. Not overly impressed with my Beat Bike Toba Crossbar. I don't use it for short flat trips as it is easier to use an ordinary bike.
Stable bike in use: I accidentally hit a surprise pothole at 12 mph and it took the impact much better than any bike I have had. Heavy weight may have helped.
#633Perseus, Apr 21, 2017
More sounds which I do not like the sound of (Zen and Cycling Maintenance) but the performance is OK, although the Toba still feels a bit sluggish and not exhilarating like the wind behind you on a lightweight bike. Quite good at the smaller hills. I've not dared yet to try it on the steeper ones.
Lights flicker. I might try it out tonight. Walking mode works, but its a pain to use, needing to keep the button pressed all the time. This I find to be essential because of the bikes weight.
#636Perseus, Apr 24, 2017
Test bike worked better. Debated taking it back. I can't specify problems, but I am worried about long distance rides. Not recommended. I feels like there is something wrong with it, but it has not stopped or missed a beat apart from the sixth gear not engaging lots of times. Cyclamatic actually sounded better before it packed up entirely.
Lights on the Toba are dynamo and front flickers at very low speeds (on start up), but are the ideal brightness and keep on for a bit after stopping.
#638Perseus, Apr 24, 2017 Last edited: Tuesday at 2:09 PM
