I won a BBS02 on an ebay auction last week,it was £380 which I was happy to pay especially as the seller had 10 to sell and only lives 30 miles from me.
The manufacturing date was 08 August 14 so it will be the 9 FET controller (I would have sent it back if it was not).
I was going to fit it on my sons 10 year old Raliegh MTB but it would have meant moving piles of stuff and both tyres were flat when it was put away (9 years ago) so I decided to go to Halfords instead and came back with an Apollo Evade (£149)
Today I started the job and removed the pedals and cranks then the BB,
Unfortunately the drive side was too tight to remove with my stillsons so I went to the bike shop for the correct socket,he had just sold the last 2 the day before he said but then agreed to sell me his workshop one as he could get another tomorrow(nice of him).
Once the bearings were out I tried to fit the motor through but it only went half way and hit something solid.
Turned out to be where the frame tubes were welded so had to go back to town and buy some grindstones for my drill (nobody seems to sell Dremels round here these days).
15 minutes of grinding away and the motor slid into place easily.
5 minutes and it was all bolted into place and the chain fitted.
I have left the front derailleur in place as it will make a good chain guide to prevent any cog jumping problems as some others have had.
I then fitted the wheel sensor, it has a sticky back but this only lasted for about 15 seconds so I used cable ties to hold it in place.By comparison my Dillenger sensor was stuck on the frame the same way 2 months ago and is rock solid.
I then fitted the LCD to the handlebars,it comes with 2 sizes of spacer neither of which fitted my standard 25.4mm bars even though 1 had 25.4 cast into it.
Luckily ,because of the bends near the centre, the lcd did fit securely enough.
Then I ran out of time as one of my boys had to go to the dentist.
I shall finish it off in the morning then testing can begin.
I will be using the Dillenger 10Ah battery and rear rack on this.
